Alpha Silber turbo
I don't think 50av/50-91 will get you there at 8-9. You can try, but i needed more.
New tune isn't any better than the previous one. Pretty lame of silber to let this go on this long.
What are you running for fuel mix & psi?
Just got the latest flash on mine and new pistons for this season hoping it is better, it did feel pretty good pulling out of the shop and into the trailer, Hoping for some seat time next week.
2200 miles on 8lbs last season, it was a good thing I did too cause I had a small nick in the pto cylinder musta sucked something through at some point. I had the pistons so I threw them in.
What do you guys have for clearance on the side panel? My padding is touching them turbo wondering if I should do something about it or just let it clearance it self.21EED696-6B46-4782-917B-E607C3B59398.jpeg
Yes a cycles and sleds set up I haven’t had any time on it hopefully next weekend will be able to put some miles on it.
Keep me posted on what you think. I purchased their clutching for my 19 silber Alpha and was very happy working with Collin. I havent put any seat time on it boosted yet. Once I do, I think I will get his turbo T/blow off valve setup. I think it would help with quick throttle response and dialing in your boost.
Will do! They did my good buddies 19 alpha that he rode all last year with silbers set up so I should have some good feedback we’re both running the full kit at 7lbs. Only drawback I can see is they recommend 50/50 race or av gas.
No your not , I had fitment issues with the muffler . He sent me another one and the boost hose was too short . I had to fix that one myself .
Sent from my moto g(6) using Tapatalk
Over the summer doing some general some general maintenance, I found my waste gate actuator had broken off it’s mount. Have had my alpha turbo out twice now running exactly 5lbs of boost. At 9,000 to 10,000 feet and running quite well on straight 91 pump gas.
5lbs straight pump no det? You running cns weights? How much weight? Any long pulls yet? Straight 91 seems scary but I bet it runs cleaner eh.
