Had an easy weekend at the cabin and some time to tinker over the weekend. Started experimenting with primary clutch springs. What I found was, the stiffer the spring on the bottom, the worse the bottom end bog got. 120 start rate on spring the bog is almost gone, not very noticeable. Go up to 140 or 160 on the spring engagement pressures and the bog gets way worse. The finish pressure didn’t effect it at all whether it was 240 or 340, but the initial pressure really affected it.
Still experimenting with octane too. Hits the det sensor with 5 gal av gas to pump 91. Torco octane boost does absolutely nothing, Torco states that 32oz to 10 gal should increase octane by 11. That’s absoluetly false. Pretty much need 3-4 gal of 110 per tank of 91 to not hit the det sensor at 9,000ft. Boost gage is at a max of 6lbs boost at 8300-8400 rpm.
