Superjag
Ok, I have been able to resist the urge to get involved in this since the first time it was posted on the old forum, but to quote that nautical poet Popeye the Sailor, "I can't stands no more!" THE PLANE WILL FLY. It is simple physics. The speed of the wheel has absolutely no bearing on the planes ability to create thrust. Want to prove it to yourself? Try this:
1. Go to a large aiprport or any other location with one of those moving walkways. (This will be your "treadmill".)
2. Put on roller skates and stand on the moving walkway facing the opposite direction that it is traveling. (You are the "plane". The skates are your "landing gear".)
3. Now stick out your arms to each side like a plane's wings. Have a friend stand on either side of you but not on the treadmill and hold on to your outsretched arm. (Your friends are now the plane's "jet engines".)
4. Now have your friends walk forward. This is the thrust of the engines. Because the thrust generated by your "engines" is pushing on the wings (and not the wheels!!!!) you will move forward. If your friends move faster, so will you. The walkway can spin faster and faster , but it will not matter at all. Only the wheels are spinning at the same rate as the walkway/treadmill. You (the plane) will continue to move forward at whatever rate your friends are pulling you along, no what matter the speed of the walkway and your wheels. If your friends can run 100 mph, you will go forward at 100mph. The only way this would not be true is if your wheel bearings have a bunch of resistance in them to the point that your friends could not overcome the drag caused by the friction of the bearings, but that is not what the scenario describes.
NOW does this make sense?!
