Aftermarket A-Arm bushings?
B, can you make replacements for the steering shaft ? The stock plastic wears out quick and gives the dreaded "bar slop".
Bparks, i'm looking for delrin "shimming" washers for the A-arms. I don't like those little "spring" washers on the stockers, and now i'm running aftermarket arms, and the spring washers don't fit. Get anything like that?
bushing
I can make the bushing to fit with out spring if that would work . I could make washers to fill the gap if that would work better for you
steering bushings
I am pulling in my pro tonight so will let you know about the steering bushings
On my SBA the steering post has a lot of slop up and down. The sled is brand new - 200 miles. Is that something that could be shimmed?
Polaris Pro RMK A-Arm Bushings
Made from high-quality Delrin Plastic, $75 a set shipped within the U.S., $80 shipped internationally. Private Message me to order.
Got mine yesterday! Thanks Bill for the fast turnaround!!
Two days
They look great, now I need some arms to install them in.
A arm bushings
I was the first to post about this, and find someone that makes them. Super Dave is a great guy, you have to call him about them, he hasn't updated his website. I got my bushings and they work great! They were $69 shipped. I knew these bushings were bad before the 2012 rush came out. I saw more of a problem with the upper controls having play verses the the lower. None the less they come in a set of 16. Give Super Dave a call.
bushings
the bushings are all most the same just the flange is different and the rush/switchback use the same pivot as the pro just a different a arm
