snwman77
Banned
So why would I need a Boost controller if I have an adjustable boost actuator?? So you know what im talking about. A boost actuator is the unit that opens and closes the waste gate and the boost controller is the little unit that has the knob that you can turn to raise and lower the amount of perssure to the boost actuator so it will open and close the waste gate as your intake pressure goes up and down. So what im asking is what is the need of the boost controller if you have an adjustable boost actuator??? You should be able to adjust the spring tension in the adjustable boost actuator and that would then open and close the waste gate according to intake pressure or am I all wrong on this?
