looking at thomas school bus with the cummins.. Took it for a test drive and it didn't seem to have any low end torque.. Talked to a friend of mine who said change the fuel filters but this one is only using a single,, it has the double housing but what I would call the primary or first filter in line from the tank has a block off bowl. I'm willing to buy a fuel filter to see if that is the problem but do you think this setup has a lift pump in the tank?? The fuel tank is close to the engine compartment it's just behind the entry door. If it does have a lift pump,, where do you buy to get the best deal. This guy bought it from a school district in Iowa and drove it here last year and it has been parked since.. I want it for shop/storage was going to buy a trailer but think this is a better route. The bus has 115000 mi. on it. The engine started right up and I thought I read some where that if the lift pump is bad that the engine starts hard not sure on that though.. When I loaded the engine it didn't emit black smoke like I thought it would.. It smoked blue from the time I started it until it warmed up a bit, not bad at idle but when I stepped on the pedal it smoked quite a bit but only at first..
ANY help would be appreciated Thanks
