ADDIE
To your first question - Yes actually I am - trust me we all wish that this was like the old days.....Where the piston actually rode on a cushion of oil. ( cast iron sleeve, induction of fuel thru the case mounted reed cage ) ..... * Oil injected into the throat of the carburetor *
Plenty of time for the spinning crankshaft to mix the oil and gas thoroughly
That being said, In vision in your head this for a moment.
In 2004 You shut off your Carburated 800 sled after a long day's ride and you hear it's going to be -30 below zero in Cooke City where you are riding. ( this sled is 130 Hp )
In 2011 you shut off your fuel injected sled after a long days ride and you hear it's going to be -30 below zero in Cooke city where you are riding. ( this sleds about 145 hp )
What's the big difference between the 2 sleds tomorrow morning after both sleds have sat all night and you go to start them ?
Let me paint a small picture for us all.
The 2004 has a wonder recipe of blended premixed laying in the bottom of the case that has drained down from shut off.... It's still thin and fluid @ -30 because of the fuel ( or Solvent which thins the oil ) it's actually just deep enough to where it most often touching the crank wheels and for sure the big rod end in the recess in the case....... You go to full choke and you start pulling and because it's so cold it takes a few more pulls then normal to start even though it fired once already from the past fuel & oil that pooled in the case.
The magic that happen while you were pulling ..... ( a thin recipe of fuel & oil was being splashed on the cylinder walls from the connection rod ) and the ice cold fuel following from the carb has oil in the throat from the little brass fitting in the carb. * this thin magic recipe is providing a instant layer of protection between the cylinder and the piston. *
The 2011 CFI 2 ( fuel injection sled ). Has straight injector oil in the crankcase with no fuel and it's thick * even VES gold was thick in 2011.....
Picture what's coming here...... The 2011 mid-cylinder mounted rear transfer fuel injector is just waiting for you ( the giant capacitor has stored a huge charge of electricity from the day before ) it's still there and it's ready.... You pull the rope once and it barely turned over the first pull.... WOW YOU SAY !! Well being that you are 30 years old and 6'-4" tall 275 pounds you anchor your foot in the stir-up and you are going to make sure that this thing spins fast this time & you just about ripe the recoil right off the motor....., IT STARTS ON THE SECOND PULL !
What just happened ? You start praising the EFI system to all your pals and you say good bye to the carburetor day..... ( what really happened ? )
The 2011 sled started on the second pull..... The rear mounted fuel injector on the first pull felt the energy from the capacitor and it opened the fuel pump spun from the stored energy in the capacitor and a fresh spray of ( dry ) fuel enter the
rear transfer port up high right by the real transfer opening and what did it do ?
I'll tell you what the first thing is it did..... It washed any trace of oil left on the back of the piston off and blew it side ways around the piston where there is no load.... Oh wait NO PROBLEM ! The rod is coming around to throw a mix of oil and fuel on the cylinder walls ..... right ?
Wrong..... Remember there is no fuel in the case.... Only thick ICE cold injector oil ( and if by chance it's deep enough to touch the crank ) there is no way at recoil speed the ice cold injector oil can be thrown anywhere.
The oil is attached to a 29 pound ciclular chunk of steel that is -30 degrees below zero....... And it's going to be a while before it gets warm enough to throw oil.
So the 2004 800 ( exact same bore size )85mm that had a fuel blend in the case almost never needed Pistons ) because the piston was riding on a film of oil.
Verses a 2011 800 .... 85mm bore at start up the piston is ( if honed incorrectly ) non-plateau finish the piston is rubbing ( not riding ) on the razor sharp fracture peaks created by the ripping & tearing effects of diamond super abrasive honing shoes.
And even though the piston alloys are amazing and the piston surface is really really hard...... The silicon carbide can cut its way through after time.
And it takes many cold starts to cut through this...... That's why mountain sleds are so hrs on Pistons ( many many starts for very few miles ) trial sleds very few starts for lots and lots of miles.
If you take a group of guys that trial ride together that are ( all on the wagon ) and REALLY ride and don't stop at ever 25 miles at a bar ) and roll on 350 miles per day these EFI motors will go easily past 12,000 I see it from time to time.
It's the cold starts that kill EFI sleds...... ( why do you the injector oil keeps getting thinner ? ) the thinner the cold start viscosity the better piston life you will see.
Ohhhhhh ! I gotta throw one little laugher in on the cold start 275 pound 6 foot 4" 30 year old that can start a -30 degree Polaris in 2 pulls.
Why don't we all buy electric start Polaris sleds ? OH THATS RIGHT I HAVE BOUGHT SEVERAL WITH E-START POLARIS SLEDS.....
Oh that's right..... The electric start doesn't work on a Polaris below zero !!
What was I thinking ???
![Pizza :pizza: :pizza:](/forum/images/smilies/new2010/pizza.gif)
ADDIE....... Do I really have to go into the piston coating thing ?
This will be another Novel ( let's just part with this for now ) it's break in coating .. Right ?
Don't get me started on coating...... Especially when we are dealing with a company that is on the NASDAG
Polaris - wrote the book on let's take the lowest bidder every time and then expect quality and dependability on the snow.
I will tell you this..... If I worked for Polaris heads would roll and there would be a housing cleaning like you have never seen. Followed by a motor to the likes of nothing Polaris could possible imagine.
And it really wouldn't be that hard..... 2 things would happen.
It would be done faster the they thought possible
And it would come in under budget
I gotta get to work.
( note ) I did not proof read this..... As you all know I am not a scholar.
And I never proof read until after I send it.... Then I re-read it later and say to myself ... OH MY GOD !!
Edit edit edit
Dan
