Have you tried the clutch kit that most of us Alaskan's are running?
My clutches are fully shifted out at 8000 rpm and I use the rpms from 8000-8400 to gain another 7 mph. In a drag race, a really low geared sled will kill a high geared one. It will be so fast off the line and will hit full shift clutch lockout quickly and the rpm will climb along with the rpm. The high geared sled is still struggling to keep up. Unless you have tried it or seen it, you won't believe it and even when you see it, it is still incomprehendible how it works so well.Kane I agree at elevation but on flatland is different and the load is also different I've spent lots of time and money. I have aeons clutch book and know it inside and out. Somthing to think about when drag racing at sea level a geared up sled will crush one that's geared down to far. Have you ever broke a belt going wide open with both clutches shifted out. There is a fine line. Trs has this down pat for elevation and understands how to make both clutches work together to achieve top track speed in different conditions.
Belt drive, custom pullies, 23/82. 8 tooth drivers.Kane, are you running gear or belt drive?
If you are going by Olav Aaens book then you would know that 1-1 is most efficient. Why not run your sled at 1-1 like Olav says?
Sent from my SM-G920W8 using Tapatalk
The secondary squeezes harder the more it is open. The belt on the primary has maximum belt to sheave contact.What I'm saying here is hitting the wall geared to low you are achieving the full shift out belt will get lose and slip without enough pull in the seconday. Why do we gear down a sled at elevation because of less power. Why do we gear a turbo sled up after installing a turbo more power.
Yes, use the axys quick drive belt with the proride gears on the 850. Here is a video i made on the install, sorry its in french but you will get the ideaif using pro ride gears to gear down, is the same quick drive belt used, or the pro ride belt needed?
thanks
