Polaris turbo section, TRS clutching part 1-4. Read it and see if you can get on board with the concept?Can you shed some light on this.... in a Full progressive helix your never are in the first and last angles. As soon as you move your out of the 42 angle and your never completely shifted out so you wont use the 32 angle. So, your suggesting that a 41-33 shift out with lighter weights is achieving better results?
Yes the Secondary spring is much lighter, (125-175) but the lighter weights and stock spring (120-320) wont allow more primary pull as you have gone backwards on effective primary shift out..
Em I missing something here?
Well, 499 CAD is only like 360 US, so not much of a difference there. I guess should have been more specific. The results were achieved at 7000 feet in 24-26 inches of fresh snow on a good base. Climbing long pulls where ground speed was no more than 5-6 mph, and would hold 47-48 mph track speed. If ground speed increased so did track speed, but thats not how I calculate REAL track speed.
Lets see some video of a 2012 pro getting that track speed in deep snow.....
The 850 only gets 40-41 mph track speed stock.
Is that track speed with a 155 2.6 or a 163 3”, I’m only pulling 40 mph with my 163 3” but I’m trying to figure out a setup on a team tied secondary
Red800. Have you taken into consideration speedo inaccuracy with the Pro gears?
2.10 ratio w/7 tooth at 1-1 is about 77mph/123kmh.Yes, the stock gears are 22/43 = 1.95
Pro Gears are 21/44 = 2.10
This a 7% gear down. The gauge would read 50-51 mph. But that wasn't the actual track speed. Its was closer to 47-48 mph.
Its about 3.5 mph difference from what the gauge says
The bottom end suffers from the straight 42 helix and a belt thats too hard. The 2016 axys belt is still not the answer.
A muti-angle helix is required to get the snap back in the bottom end along with a softer durometer belt and softer secondary spring.
