V
Vi-PEC Powersports
We have more than 2000 engine dyno passes on the polaris engine, more than 25 000km on the snow( only us) n/a and turboed , all with our ECU. There isn t one rule for all the kit you can apply. There is so many variables in the 2 stroke environement ...... The best i can say for now is make sure you have a solid tune, change fuel filter every 1500km, change pistons every 3000km (the rings get loose even on a solid tune) and do properly size your turbo on your setup( most frequent mistake from the turbo manufacturer) , if you are realy going for long term reliability a water to air intercooler is a must ( personaly, i wouldn t run what ever turbo kit without HM TURBO intercooler, keeps charging temp in the lower 30 celsius at any given throttle/pull duration vs 80-100 celsius without it...... factories are spending millions of $$ in R&D to produce as less heat as they can with their engines, heat is an engine ennemy.finaly fresh reeds ( with reeds stop) every 3000 km is recommended also( reeds are working a lot on a turbo application and are extremely important component). So, performing those maintenance operations will save you a bunch of headache. Now you just need to pray so your fuel pump does go, your stator doesn t start to malfunction, jackshaft hold together ect ....
Vi-pec powersports
Vi-pec powersports
