Is a single pipe better for a turbo setup? or would twin pipes or triple pipes on a triple make more power with a turbo?
we gained over 90 hp going from the cpi single to crankshop twins on the rt turbo at dynotech , same boost.
god loves those who think OUTSIDE the box..
uncle donny installed the msd on the big 4 holer..now he can have fun.
dont forget about me voodoo
Are the turbo twin or triple pipes any different in shape or volume than the N/A performance pipes?
Nope
Just watch for leaks and hook turbine as close as possible to the taper of the pipe with a short stinger.
The stinger diameter might need some attention depending on exhaust A/R being used. You need to keep pipe pressure over boost pressure at around 3 to 5 lbs @ w,o , if you go to much you WILL!! cook pistons.
I do know what size is going on my new build, 07 machzgade 1000 carbed with a gt3582.
What is that?
