A
Anchorage yamaha did a weigh in for all the manufacturers. Pretty sweet!
Sent from my SM-G991U1 using Tapatalk
He says 12 lbs of extra fuel??......2.5 x 8lbs is 20lbs lighter on top of 32 lbs = 52 lbs lighter !!It’s really pretty crazy the Polaris holds over two more gallons of gas and is still that much lighter.
The weight is probably in the track. If they are both le's the 154 has the 2.6 2.86 track and the 165 is a 3in 3.5 pitch. That 2.6 is a really heavy track. But I could be wrongSomething doesn't add up on 154 mountain max
Fuel weighs 6.1 lbs per gallonHe says 12 lbs of extra fuel??......2.5 x 8lbs is 20lbs lighter on top of 32 lbs = 52 lbs lighter !!
Did he say 12 lbs more fuel in the Polaris for these weights?568 doo
532 boost.
Both 165’s full wet.
Yep the 154 2.6 weighs 62.2lb and the 165 3 weighs 52.6lb according to Cat specs on those tracks. Those Yamahas also have electric start which puts the heavy old seat and tank on them on top of the other E-start components.The weight is probably in the track. If they are both le's the 154 has the 2.6 2.86 track and the 165 is a 3in 3.5 pitch. That 2.6 is a really heavy track. But I could be wrong
Sorry, yes US gallons 6.1.Fuel weighs 6.1 lbs per gallon
