THIS IS INCORRECT. ALL DURAMAX TRUCKS COME WITH 3.73. HAS BEEN THIS WAY SINCE THEY CAME OUT.
I as many trash talked the 6.0L for years and what a shame it was and how Ford screwed up! Then I learned the truth! Only a small percentage of the early 6.0s actually had engine issues! The high compression injectors and piss poor maintenance of them and the engine in general did it in! Look up on most diesel forums and do more research! The problem was poor maintenance of the whole truck! Yes international made the engine too finicky! And the EGR was killing all engines it was on! Poor maintenance of the batteries ruins the FICM!
New word to be entered into the next edition of Webster's dictionary.....
Rofftard - One who is unintelligent, un informed and or ignorant.
ie - Toby is Rofftarded in his beliefs of what quantifies the quality of a pickup truck .
This thread is Rofftarded, always was and always will be!
Ok the 7.3 injectors never ran at a 26, 000 PSI But I read that in a book somewhere oh ya it is the service manual! But I better check to see if I can find a newer revised one!
So... Is this going to be in the 1/2 ton category??? If so... Its not the same class as the 3/4 ton on up. JMHO
http://www.autoevolution.com/news/toyota-already-testing-diesel-tundra-truck-70761.html
where do you guys buy trucks from, i guaranty my duramax has 4:10 gears i wouldnt buy one without 4:10
Ok RibbedRider, there's 1 of 2 things going on here......
1 You don't actually believe 90% of the stupidity you are posting, you are just trying to keep it interesting around here.
If that is the case, well played & I kinda think you're ok.
or
2 You are drinking the same koolaid which you are pouring, well then I guess you are in this cyber community because you have been cast out of the virtual community. In which case I would bet you are not even a snowmobiler.
Well BRING YOUR HAPPY @$$3 $ OVER AND PUT YOUR TRUCK THOUGH THE PACES AND SHOW MY 6.0 UP! TILL THEN!!!!!!
or
For now I will give you the benefit of the doubt and assume #1
Keep stirring the pot brotha!
