when is the next time you can get it out ?
i'm leaning toward clutching for you cause of the high Rs you seem already
i've never seen anywhere close to those Rs
i wonder if there's any chance you've got a higher psi spring in the BOV ? worth a check do you have a boost gauge ?
the 7t drivers will gear you down quite a bit so that will play into clutching as well
did you say your running 10 lbs of boost ?
