Complete Silber Turbo kit from a 2013 Pro RMK 800 with 1841 miles. The turbo and kit could have much less mileage than that. I do not know. The included ecu is flashed to run the turbo system . No control box or tuning required. Larger injectors and Boondocker EBC for boost control and altitude compensation. All the needed clutching items are included.
AEM Fuel ratio gauge
Boost Gauge
Rooster Clutch weights
Secondary helix and spring
Boondocker EBC
Larger injectors and wire harness
Silber Turbo with oil tank delete update *uses stock oil pump*
Throttle bodies with billet adapters installed
Silicone tubing and cold air intake
5psi to 12psi boost
Located in Colorado USA 81230
$1300 shipped
Boost Gauge
Boondocker EBC
5psi to 12psi boost
$1300 shipped
