2012 Polaris RMK's Running Hot?
OS:
Springtime tree riding on firm snow is a big problem. I would have to continually stop and pack snow on the top of the tunnel to cool things off.
Hey Z! I expect to have to do that in the spring. I just wish we would get some more snow now!!
Ben I have 170 miles on my 12 PRO and have found the relationship between speed and the need for the scratchers a bit interesting. If the snow is hard, it takes more than just having the scratchers down to keep the temp below 160. If you are going around 15 miles an hour or so, on hard snow with the scratchers down, the temp goes up very fast. Move the speed to 25 or 30 and it drops just as fast. It seems the coolant flow through the system is not adequate at lower rpm's. It's hard to imagine that there is that much more snow spray on the exchangers?? I wonder if the water pump flow rate is as much of an issue as the amount of heat exchanger surface area? This is a great sled, but I like to boondock in the trees and many times that means working slow around things. I suspect it's going to be hard to keep the temps down under those kinds of situations on hard snow days.
Bingo! My thoughts exactly. Consistent high temps at slower speeds even in fresh. The 2011 DOES NOT get near the high temps as the 2012 in exact same conditions. I had my dealer check for air in the system, etc and they found no irregularities. Has to be the flow of coolant thru the system - makes sense to me.
Thanks for you input on this. After January 3rd I will have my sleds back from rentals to where I can test several sleds and really post some results concerning the temps with and without scratchers. I am also consuming a very small amount of oil on the 2012's. I am going to start measuring accurately. I am concerned that this small heat problem now will be huge under spring conditions.
This is very intereating. I am going to check into this with my dealer here in a few days. Thanks!
Rockin,
I forgot to mention that the cooling system on '11 models appear to be set up the same way so I doubt that it is the design, per se, that has caused increase in temps. from the '11 to '12 RMK..............I just feel the design is questionable in that it doesn't make the most efficient use of the front & rear coolers.............If you're interested, you can browse the on-line parts catalogue at Pure Polaris...........
There are a lot of modifications that can be done to improve the cooling system on these machines however I can sympathize with your frustration in the fact that you shouldn't have to be "doing" Polaris's engineering for them by installing additives in the coolant, changing snowflaps, adding aux./extra coolers, etc...........Especially when competitors produce machines with cooling systems that perform properly "out of the box"..............
In your situation, the cheapest solution might be to install Water Wetter and communicate as effectively as possible to your customers the need to use the ice scratchers & monitor the temp. display.............
FYI, I own an '11 Pro so my post is not "brand bashing" in nature............
Glen
They all have scratchers now. Until this year, a regular model RMK didn't need them under these conditons. Even Yesterday with new snow on the trail, one of the 600's hit 205. I have a feeling that something will be discovered before too long to why this is happening excessively. Thanks for the input.
Sounds like Water Wetter is worthwhile. How many oz are you adding to the coolant tank? I believe that the recommended concentrate is 1 oz per quart? Thanks
Im just glad Poo decided to put temp gauges onn these sleds
Mine went down yesterday
Was riding some hard pack snow and went into a field to cool things off
Was playin around and watched the temps go from 123 all the way up to 198
No temp light came on
I shut it down and opened the panel and there was ZERO coolant in the bottle
Lid still in place and the engine bay was dry
Cant figure out where it when but it looks like maybe a pinhole or something in the front HE????
Not sure but i lost it fast so maybe not a pinhole
Ran great and normal temps all day them boom, nothing
But it was all piled up near the front of the skid
Goin to the dlr tomorrow to see what happenned
Hate to even say it but could there be some leaner mapping on the '12's that you guys are getting into at trail crusing speeds that could make them run hot?
I measured oil consumption on three 2012 600 rmk's yesterday. All three sleds used 4-5 gallons of fuel. Two sleds used 8 ounces of oil and one 10oz. Ski-doos on same ride, 20 oz and 26 oz. There is a serious problem going on here.
There has been a lot of discussion about the oil consumption (or lack there of) with the PRO 800. There are many ideas, opinions, theory's etc. but I have not seen any official word from Polaris on the oil consumption, what is required, normal, and why they burn SO MUCH less than older Polaris 800’s. I fear it’s the pressure from the EPA, driving this. If the low oil consumption is not bad for the engine, then I would like to know what has been done with the design of this engine to require such a significant reduction??
Polaris... if you are listening, please let us know what is the reasoning behind the reduced oil consumption....
200? your cooking the thing. get scratchers on it. should stabalize at 120-130
temp lights flash at 167
Is this accurate for the 2012 800 Pro RMK? I was out in Walden, CO and I saw 200 degrees but no light (briefly was off in the first powder I could find). I was riding with Summit 800 e-tech and he saw his light come on so I don't think we're alone in running hot in poor snow.
I have ran down a really hard trail about 6 miles at a pretty good speed scratchers down and never got above 125, 2012 pro. No scratchers down = no hyfax in about 100 mi.
Just going to throw this out there but since it seems some people are still experiencing hot temps even with scratchers down, do you people have alot of things installed on the tunnel? (tunnel bags,gas racks, ect...) Dont know if maybe that could affect the efficiency of the cooling process? My tunnel is bare and Iv never gone over 130* with scratchers down in almost all conditions. Just a thought?
That's roughly 70:1!!! :face-icon-small-sho
I wonder if the oil injection pumps are adjusted correctly???
It might be worth it to pre-mix the fuel in your tanks with about 10 - 15 oz. of oil to see what effect that has on your coolant temps until you can get the machines to a dealer to be looked at............
This topic has been beat to death. Many (including me) are turning up our pumps, and running oil in the gas tank. I still have not seen a good answer for the little use by these engines. You can do a search of this forum and find long threads on the subject, but no real answer or proof that for some reason these engines don't need a more normal amount of oil from the pump.
it may really not be an issue, but I find it odd that the PRO 800 uses less than a quarter of the oil that my wifes old 05 Polaris 600 RMK used???
I like the idea of not having to buy so much of this expensive oil, but I wonder what the long term ramifications will be??
I add extra oil to the fuel tanks daily until I feel comfortable with what is going on. Heard that several 600s went down this year due to oil pump bleeding issues. My dealer bled all of my oil pumps.
After seeing the lack of oil consumption I am not confident that the bleeding is the only issue or solution.
I'm a little worried about my 800. It's on par to use about 4 tanks of oil in 1000 miles. That seems scary low.... :bolt:
130 miles on her so far and it looks pretty close to half a tank of oil.
Edit: It's been mixed 50:1 so far though for break in. I think I should turn up the oiler and mix at 100:1 now.
Has anybody called Polaris direct and asked? Just a thought. I plan on calling them regarding the temps and will also ask about the oil consumption.
Wow if I would have known the issues with the 6 I would have passed on Polaris . Its the wife's ride and I wanted it to be an excellent experience not a hassle of mixing fuel and oil and worrying about heating and cooking the motor , sheesh our season is to short to be plaqued with major issues .
I wouldn't worry too much man. From the sounds of it you haven't even got it out for a ride yet. Just take it out and see what happens. I haven't had any cooling issues on my Pro yet and the Pro is the one missing one of the heat exchangers to save weight. On fairly hard snow I saw 145 with no scratchers down. I'm sure I'd be down at 125 with the scratchers.
