X3....at this point, I'm almost wondering if the definition of the word "offset" is translation in Polaris language for "thicker skirt" LOL...
But anything is possible...
Another thing to consider with regard to cylinder skirt breakage would be the possibility of excessive clearance of the cylinder skirt to the Lower case fitment due to machining differences. Member 2XM3 discovered this a couple seasons ago on the CFI-4 and was the first to post about it. I measured a 2010 last season that had 0.009" of clearance between the cyl skirt and lower case.
The support of the skirt by the lower case is/has been my concern when using a shim plate in some of the aftermarket kits even though there doesn't seem to be any evidence at this point that it is actually an issue.
I haven't seen an 800R Rotax cylinder (particularly the skirt) for a while, and I believe Kelsey has said they are thinner than the Poo. Is the height of the Doo cylinder any taller than the Poo 800???
