Same driver one extrovert center......
You work on everything basic and easy from the side panels...exhaust, head pulling, and more extensive stuff you simply dis-assemble the center plastic (couple screws) and pull the support bars...possibly dis-connect the steering link.
handlebar stock ride height is 37 ish from footbed to grip/bar...about an inch taller then the stock 2010 dragon
Side support tube is now aluminum and it sounds like a placed insert but that is not defined. It's absolutely a larger diameter support but out of a different metal so who really knows the actual yields. This is my field of expertise so we put some added stress to it and I think you will find it to be similar with the 2010 in yield (Bending point or the point at which it won't return to it's original state). Your stock 2010 support bars can take 330ft/lbs at direct point pressure before they don't come back to the original state. That ain't much and isn't really enough as you can see from the thousands of wowed out ones running around. The style of the foot bed firms things up significantly so that will help a little. When guys buy this sled and see the value of Better Boards that will add even more "strength" in that aspect but I'm guessing that down the road we will be putting out another aftermarket product along the lines of our Better Bars for this sled. We'll see how many they sell and how things perform.
TBTURBO in on the 24th in Jackson we will release our all new Better Bars for all Polaris IQ RAW chassis. Check em out there, or online (
www.snowmobilebetterboards.com) by that time. Lab reports just in 66% higher yield with 33% thicker inner wall diameter ...tie that with some HD (big boy big air version) Better Boards and you get the best of the best for the big boys that really get it done! (available in all colors as well)
here is one of the test sleds (looks just like stock except way stronger)
