I
IceCap
I will check that ground location.... I don't believe it is a plug or plug wire issue.
It seems that a lot of us are experiencing this issue ONLY after the sled has done several longer hard pulls.... which leads me to think it has to do with build up of heat... not water temps (they barely go up) but rather pipe heat.
Either the fuel map can't compensate for the higher pipe heat or the pipe sensor is not working correctly.
I think Polaris is in denial on this issue.
