Hey everyone, sorry for the delayed response.
Finally got to take my Pro out and do some more testing etc. Before the ride this is what I had done:
-throttle freeplay tightened up (although there was very little play)
-tps checked, and dielectric grease applied
-primary spring, weights and rollers checked
-added injector cleaner to fuel
-stock silencer installed
-grounds were checked and reinstalled
-power valve hoses were cleaned out
Unfortunately, none of this solved the problem. The sled acted up all day. The bogging problem had changed though. Using the playback function, I find that on a big pull it will start out at 8100 approx. and fluctuate a bit from 7900 to 8150, then maybe 8 seconds in at WOT the rpms would kick down to 7700, then back up to about 8000, then kick back down farther to 7400, then back up to 7900ish, and then kick down again to 6850. Near the end of the pull, it would be down to about 6800 rpm, felt powerless and I would have to turn out.
This was all running about 5600 to 6500 feet, with 62 gram weights.
I also tested in on the lake, and using the playback function, found that it would start out at 8050, hold it for maybe 3 seconds, then sink down 7700 and hold 7700 for about 15 seconds.
Now it was funny to me that is would act differently on a big pull and going across the lake (these are both very similar altitudes). Could it have to do with sled orientation?
My first day on it felt like it was running out of fuel when it bogged, now it feels a lot different, as it catches itself and regains rpm, but then kicks down once again. Also, about 1 in 3 times, when you start it up, it will idle very low and the display won't even show up, and it will stay at a very low idle just fine. Tap the throttle and it will idle normal and the display will turn on. Could this once in a while low idle be related to the rpm loss?
I just went through a similar problem on my M8, it would hold rpm, then it would kick down, then build back up etc. That turned out to be the rollers in the primary, this problem on my pro seems rather similar. But the weights, rollers, and spring in the primary are in great shape.
Anyone have any other ideas? I am going to try and pick up some 64 gram weights and try them out. My dealer is 5.5 hours away so it is a hassle getting the sled to them, but I will do it if necessary.
Input is greatly appreciated! From the way it sounds, a number of people are having this "bogging"/rpm loss problem and it would be great if we could solve it for everyone!
