When mine stuck twice on every rotation is was missing track clips. Warped disc you should feel in the brake lever. And the dealer said they checked the bearing on that side.
check and make sure your helix has not sheered some of the screws or if their loose on the back of your secondary clutch.
i have seen this s couple of time this year.if the motor mount rubber breaks free you well fell alot of vibrating in you feet.Just looked sled over and found a piece of the helix was broke off. Not sure what was the cause but I only have 300 miles on it. Hope I can get it fixed by tomorrow.
The sled used to over rev slightly at home now it doesn't at all. RPM's are low. It won't pull out of the grindy zone under load. Even when you pin it. Sometimes when you pin it, it will rev/speed up a bit, then grind down, come up a little higher, grind down again pull up even higher, grind down once more and then be WOT with lower RPM than normal. It's really weird.
