It seems obvious that the 3" out performs lining up and heading straight up a hill, but what are the differences in handling through the trees...what the pro is made for
Goes thru the trees like a squirrel.
My buddy's sled=14 Cat M8000, 163X2.6 power claw.
My sled=13 RMK 800, 156X3. X3.
Both stock engines.
Deeeep powder in December. Both stock on mostly flat ground side by side.
We stamped out snow under belly. Lifted rear bumper once.
Neither were clear and "free".
I jockeyed both sleds in the name of science.
Used "wiggle and pin it".
The Pro lifted and walked away.
The Cat dug deeper and never moved forward more than an inch.
No lie.
Lots of variables to consider....but the track WORKS!!!
He rides my sled... He admits it also. He might be checking a 16 with a 3".
I REALLY want to compare the 3" X3 to the 3" PC.
PRETTY HARD to isolate all the variables there, though, unless you got identical chassis with those two tracks.
LOL. That's not even close to a comparison of tracks Scott. That's a comparison of chassis'.
A comparison of tracks would be Pro against a Pro. Your geared down 156 3" and a similarly geared down Pro with the stock 5.1.
Bet ya it would be close with the 5.1 running away by the end of the meadow or ravine or whatever flatish terrain you were on.
I don't think someone can dispute the benefits of a 3" on a straight open climb.
The older I get, the more I like to spend my time in the rhubarb. My question is, how is the 3" in the jungle. You know your in the tight trees. You have no run, you come around a tree(s) and you need to jam the throttle and go hard left and up. You have been there.. It can be sktetchy. If you haven't, you should try it, it's a good time.
That's where I want just a tick more help. I fall short in that situation once in a while. When you get in that tree sugar it gets a little hairy.
Justin, spend two hours on my sled.I'll let ya.
