more great questions.
are you going for wiseco or oem piston in your small block 800 package?i have some serious piston slop in my 2011 pro,dont know if it is normal,or it is because the very low oil usage.cant find any info on running wiseco in cfi2 motors.what is your take on it?
I will be using cast pistons for most applications, Cast are more forgiving and under normal use conditions last much longer. Wiseco forged have their place, Even though not a big fan for a daily driver. back in 1999 I ran Wiseco's in my 700 Turbo..... WAY better then the OEM elko piece for a Turbor for my application I was runninmg alot of boost and on the edge of the fuel I ran and if I got to close to the edge and deto a OEM ELKO piston the ring-land & rings crumbled and thrashed the turbo. Once I fittted it for Wisecos you could stick it or deto it and the piston & rings were soft enough & did not break apart.
" QUOTE " So is the success of the "fix it" kit in your opinion due to running pistons that are in spec and not because of they changed pin location? As for the " FIX KIT " It was the first thing to come to the table and it is better then putting one back stock. as " QUOTE 2XM3 said " It moves the piston up away for the trouble problem. His explaination is right on track. Well said 2XM3.
Because the rod is so short the piston comes down to far and cylinder sleeve extends down to far to try and support it. ( kind of a good Idea ) but not really....... Because the 85mm bore the sleeve is not thick enough for its length and the leverage the piston has over time snaps it off.
The " FIX KIT " does help reduce the leveage length of the piston, And then add to the FIT KIT, a cylinder that is the right size & the slapping effect is also reduced. Its like ( Blue Printing ) even a bad design.... is better if all the little imperfections are minimized.
2XM3's example of short verses long rod motors a great simplified explaination.
One most always keep in mind with the internet we are talking to a massive field of people and the same thing is not always great for everyone.
Their are people that drag race, hill climb, mountain ride, and trail ride, bar hop, lake race, and so on. My busines back in the 80's & early 90's was all about bar hoppin & lake racing, the mid to late 90's started to be all about long gevity.
Again great posts people.
Dan
