09 M8 Turbo bd control box
Status
Not open for further replies.
A
arctic matt
I need some help here guys, my 09 M8 turbo after I run it up a good deep steep powder hill for a good long climb with mostly full throttle my sled will shut off, first time it did it I thought I had blown the motor. The sled will try to start with sputtering and popping (limp mode?) I pull and pull and end up towing it off the Mountain. The sled still won't start after 12-24 hours....still in this strange mode with the same symptoms above. I have tried Thatchers technique of turning the kill switch to off and pulling 3 times and then back on with full throttle....does not begin to work. I have read several threads on heat soaked and temp sensor toggle switch. This sled has the toggle switch on it. The sled will eventually just start one morning and then I go back up the mountain and have no problems at all until I forget and take a couple long side hills and a good climb and boom, sled shuts off and all over again??? Help anyone!
Status
