09 diamond drive leaking from output shaft, bad bearing?
So my dd has been spraying fluid all over the clutches, is this a case of bad bearing? What would the bearing number be that replaces it? I noticed fluid on the outer lip of the cover where the output shaft comes out when my sled sat for a few days.
Could be a seal only or possibly a seal ruined by a bad bearing.
Is the oil level up to the fill hole, or above?
Are you using the vented secondary mounting bolt, OEM?
