07 rmk 600 155, help with cornering!!!!
My wife rmk is horrible to corner (it just wants to push away), Where my xp rails. Even at slow speeds still the same thing. I've put new sly dog skis on which helped abit from the stock one but still wants to push away.
Any set up advice?
there should be a pin holding the ski on and there should be two washers that are about half an inch thick or so. you can put them both on the inside to give it a narrower ski width, if you put one on each side its a little wider, and both on the outside would give it a wider ski stance. I moved mine from outside to inside, it is easier to throw around in the powder but wants to tip when cornering. might be something to check out
The problem is on the trail or slow speeds just turning. Laying the sled over in the powder is not a problem. It feels like there is no ski pressure. Also we go it set up now at the widest ski stance, it was too tippy norrower.
on my sled it does the same thing because i took the limiter stap and let it out all the way so i dont have that much ski pressure its just me and how i ride it sucks for trails but im not a trail riding at far out as the limiter strap the less ski pressure mess with that too and it might help
Got the limiter straps in the mid setting. We ride in the mts all the time but the trail ride up and even slow turns in the mts it's terrible ( not pow turns).
The slydogs are horrible for pushing thru the turns on my IQ's
UNTILL.
You run the "Stud Boy" shaper wear bars.
These are my favorite ski now.
Night and day diff from stock
My 2 centavos.
Happy New Year!!
Upgrade to '08 or newer spindles, find some Bergstrom skags or 1/2" or 5/8" wearbars with at least 6" carbides.
