05' m7 recalls.
recalls
there is one on the wiring (tail light harness) under the bumper, some were shorting out, also new seals in the diamond drive, the seal was installed backwords and water was getting past the seal. If you send me a PM with your vin I can check if they have been done.
good luck,
Kenny
Buttars Tractor Tremonton, Inc.
1640 W. Main
Tremonton, Ut 84337
435-257-7000
If I remember correctly there was also a recall on the 3 bolts coming out of the secondary clutch cover to hold the nylon spring adjuster.
good luck,
Kenny
1640 W. Main
Tremonton, Ut 84337
435-257-7000
Thanks to the both of you so far, I'd like to see more coming.
they also had an update on the bolt that runs from the brake side to the dd side and they losing speedo sensors quite often thats all i can think of
There was also a problem with the gas tank splitting at the filler neck. The fix was a plastic ring that snapped into place inside the neck to prevent it from cracking. Take you vin number to your local dealer and have him run it to see what has been addressed and what needs to be done. Mine fixed it all for free, as they were recalls from cat.
