T
ttreewalkerr
Kinda scary issue,, held on as lower control arm snapped and went into ground,, lucky i was only going 50 or 60 when it happened. (Fast trail)
Must have cracked last season from somthing,, corrosion set in,, and just flyin down a road,, BaHHMMMMM, snow started flyin from the bar going straight down like a rutter !!
So when i looked, it was the rear pipe from that arm,, but the front pipe of the lower arm was fractured about 10hrs around... Had to get back, was alone, and knew when that next pipe breaks belly's gonna hit ground and ski and shock will bend all over.. So i roped it up like pic shows, and baby'd it 30 miles,, about 20mph. (Ya, thats the speed and RPM that suck's on a 9)
Accually made it back... When you lifted on the nose, the crack opend up about 1/2mm... Scarry..
All welded up now, sleeved inside tube and re-weld..
