Problem 1. With the KISS coupler you have to cut off the limit stop.
Problems with that: You cannot return to stock and you can gouge out the inside of your track
Fix: Move the coupler cross shaft back so the stock limiter still works, no cutting required.
Problem 2. With the KISS coupler contacting only the outside edge of the scissor, it smashes it and bends it until it breaks.
Fix: Add a spacer block to the scissor that spreads the forces over the entire face of the scissor AND and internal spacer that also spreads forces to the backside of the scissor.
Problem 3. The KISS coupler is not easy to change positions as the springs are stiff and you need to push the blocks against the springs and turn each side individually.
Fix: Rotate the entire shaft and not just the blocks. We put machine nuts and rubber backed washers on the ends of the cross shaft so you can run just snug enough so you can still turn the shaft. A added bonus of moving the shaft back was more room to get your hand in to rotate the shaft. The blocks are self leveling so turning accidentally is unlikely.
Unless you are seeing other problems I am not addressing here?
