I could do it in 30-40 min if I wanted to but I like to take my time. I just put on some good tunes and spend hours on end going through things on my sled.
Hear is a list of things I need to try and get to this week.
I will look into that rope.
I am going to pull the engine and set it in the basement of my house and go through everything on it.
I am doing the following.
Re-torqueing all the bolts on the front suspension, steering and check all on all the motor mounts.
Taking the head off to check pistons-sleeves for any wear/build up
Removing all the paint from the head and grinding off the letters. Then i am going to polish the hell out of it.
Putting new carb boots on ( mine have a cut in them from being put on and off 1,000,000 times
installing dial-a-jets
making a new airbox
making a aluminum guard to cover the jackshaft
installing the new a-arms
moving the rear skid down about 1" in the front and cutting a bit off of my rails
retourque all suspension bolts (fawking rear drop down bracket comes loose every 5-6 rides)
Install SLP fender vent from IQ RMK chassis
Making an aluminum plate to mount my koso EGT gauge on the hood
moving the over flow jug away from the pipes
Installing cheap aluminum hose guards from napa on all the hoses that COULD rub on some thing
Redoing all the wiring and hooking up my RSI bar warmers
THEN i get to put it back together, put my new tires on my truck, then im off for another test and tune ride...
