B
Did i just stick a potato in my tail pipe.?
Bought a new light weight single can and after chopping it apart I noticed the inside diameter (id)was only 1.800.
By looks thought it was 2.350 but it's necked down way inside there making it 1.800
The inside diameter coming out of my pipes is 1.250
So out of pipes is 1.250 going into can pipes which are 1.375 which dumps into can which is 1.800 and exiting 2.350.
So originally thought was dumping pipe 1.375 into 2.350 pipe but i.m not because inside of can is necked down to 1.800.
So did I just drop $300 to put a potato in my exhaust to decrease a bunch of HP ?????? Not mention the time to hack and whack the can to fit.
You would think the manufacturer did a flow test but I have read many times where a can decreases performance and in this instance now I can see why.
They don't have a picture looking down the tail pipe in the adds so couldn't see this online.
Psi modblaster can 13.70 pounds! Hacked up dyi can 7.4 pounds. Big difference in weight. Always hated removing the psi can because it was so heavy and after my bearing swap out for new ones had enough of it and bought a single can.
Was paying more attention to the girls in math class than the teacher.Does anyone know how to calculate air flow without a machine. Where I ride can't get 2 sleds side by side without killing each other or one catching the other guys roost.Would be simple if could just take both cans out and swap out to see if one was better than the other as far as performance goes.But I can't
Any help would be very much appreciated. Common sense says I made a big mistake only after I cut it apart and looked inside.
