B
I took the machine out a few weeks ago the day before an ice storm hit our area (OR). It started the second pull from cold every time, and the first pull when warm.
I left the cat on my sled deck during the ice storm for about a week. She started right up after that week and I pulled it off the truck. While driving it towards my shop it would start beeping like it wanted to kick into reverse a couple of times so I had to either push the button or hold it (can't remember).
During my ride, I noticed the starter motor gear lying under my clutch and figured out why my electric start quit working on my last trip. I didn't look into it back then since it started so easily with the pull cord.
Since I had the time and the gear in my pocket, I figured I'd re-install the gear while the weather is garbage. Both snap rings had come out, and I was able to install new ones without pulling much apart. I just had to remove the rubber boot at the tie rod and pull the hood.
Since this repair a few weeks ago, my machine has been dead.
Compression is at 150psi.
Fuel pump pumps up to 41psi or so and then drops after I pull (I think this is normal?)
Spark is good at all plugs.
Pipe is pulled for this diagnostic work --- will the pipe being removed be the cause of any issues?
With plugs removed, it pulls over easily.
With plugs installed and machine cleared of gas it will pull over once easily, once semi easily, and a third pull is very difficult. Sometimes on the third pull, it will backfire and sometimes start for a half a second. I then have to pull the wires from the fuel injectors and pull many times until pulling becomes easy again.
I bench tested the injectors and they seem fine. With power when pulling, they inject fuel on the 2nd pull but not the first. I'm guessing this is normal? With no power--injector wires removed they don't inject fuel as I would expect.
Since it gets hard to pull only after trying to start it, I'm wondering if the bottom end is flooded. I currently have the machine flipped upside down and tied to my shop rafters to drain anything out of the bottom end.
I can pull the dang thing not stop and it pulls very easily with plugs removed. This, along with the good compression leads me to believe there's no engine issue.
Any ideas? I have an annual trip planned in two weeks that may be cancelled if this isn't fixed. I currently have a new fuel rail and injectors on standby, a new ECU, and new fuel pump. I mass ordered just in case I could track down the issue.
