Perhaps I missed it in an earlier post, but if "perfect" alignment can be achieved should the driven be flush against the shims and all of the float be to the outside? Or should the float be set so that the driven under "perfect" alignment conditions is centered in the proper float range, i.e .030-.050?
Float is to the inside after getting your off-set correct you remove shims behind the driven to add float. Here is some more detail on what I did:
http://snowest.com/forum/showpost.php?p=1021622&postcount=318
