P-22 Removal Question
IDspud
4,001
Oakley, ID
Table of Fluid Bulk Modulus (K) Values​
There are bulk modulus values for solids (e.g., 160 GPa for steel; 443 GPa for diamond; 50 MPa for solid helium) and gases (e.g., 101 kPa for air at constant temperature), but the most common tables list values for liquids. Here are representative values, in both English and metric units:
English Units
(105 PSI)
SI Units
(109 Pa)
Acetone1.340.92
Benzene1.51.05
Carbon Tetrachloride1.911.32
Ethyl Alcohol1.541.06
Gasoline1.91.3
Glycerin6.314.35
ISO 32 Mineral Oil2.61.8
Kerosene1.91.3
Mercury41.428.5
Paraffin Oil2.411.66
Petrol1.55 - 2.161.07 - 1.49
Phosphate Ester4.43
SAE 30 Oil2.21.5
Seawater3.392.34
Sulfuric Acid4.33.0
Water3.122.15
Water - Glycol53.4
Water - Oil Emulsion3.32.3
Teth-Air
4,564
2,794
Calgary AB/Nelson BC
www.specified.ca
English Units
(105 PSI)
SI Units
(109 Pa)
Acetone1.340.92
Benzene1.51.05
Gasoline1.91.3
Glycerin6.314.35
Kerosene1.91.3
Mercury41.428.5
Phosphate Ester4.43
SAE 30 Oil2.21.5
Seawater3.392.34
Sulfuric Acid4.33.0
Water3.122.15
Water - Glycol53.4
So I say again. If you compress any of these liquids to 1000 psi under a clutch, they will all exert the same forces to push the clutch off. It does not matter if they lose a fraction of the volume from compression,, the same pressure reached will exert the same force on the clutch. Think about it, when you do the "water trick" you are pressing the liquid and if a particular liquid can compress a fraction, the bolt will only have to turn in a bit farther, and the same pressure will be achieved.
IDspud
4,001
Oakley, ID
Say it a thousand times.
You yourself said one needs to turn a bit farther.
All liquids are not the same.
Many different ones can be used and results can and do vary with each clutch and situation.
Teth-Air
4,564
2,794
www.specified.ca
Yes in theory the clutch bolt can turn farther but you can't measure compression of a liquid, outside a very high end laboratory that can produce extremely high pressures and actually has the measuring capabilities. For all practicle purposes liquids are not taken as "compressible".
K
Nov 30, 2008
344
429
Reno, NV
Just heard from Polaris.
Warranty was up in January.
They are replacing the crankshaft, clutch, bolt and belt under “goodwill repair”
Can’t complain too much about that.
Are you going to have them do (pay) a top end while torn apart? By buddy's P-85 did the same thing with 1K miles and that's what he's doing
A@ron
165
88
Wisconsin
This is what I found when I was swapping to a P85.
150 miles on this P22. No scuffing or markings on the crank.
Most definitely a reminder to listen to TJ and lap this piece of **** if you decide to keep it.
Cheers
