E
I have an 07 M1000 with a boondocker turbo kit,with PureLogic box exchanged from BD box.I got the ecu wet and eat a piston,so I replaced both pistons & rings,jugs are good(compression tested to 115psi = both sides).Also checked out reeds,replaced them while it was apart.
So the problem as stated was it runs and idles just fine,you can bring the rpm's up to a certain point,then the mag side goes way down on egt to 300*,but if you feather through it and get the rpm up enough to spool it up,it will burn off the excess fuel and pull good,but once the egts cool down abit,if you hit the throttle,it falls on its face again.If you keep it on the pipe,its not bad,but oviously something is wrong.
Once I first got it all back together and running,the 1-7 code came up,so I changed out the exhaust temp sensor,now,no more codes.Any ideas or experiences with this.I have egts,a/f,& fuel press.gauge to monitor everything,fuel pressure is at 40psi + on boost.Just seems to be flooding on side.I'm thinking injectors or coil failure,but there are no check engine codes,so could ECU be pouched,whats next??? I'm going to change out ecu and see what that does but shouldn't there be a code if ECU is faulty?
