M
Yes, I am a big bore m8 and before he was always just shy
anyone tried this on an 06 with the float conversion? Geo do you have any experience with this?
I just did mine this last weekend and of course have not been able to ride it yet. Everything seems like it is going to work just fine, the only question i have is the suspension stop does not touch when the suspension is fully extended is that a problem? With the suspension fully @ full extention there is probably still 1/2" between the suspension support and stop bar.
I hope this mod works as advertised I too have the 2.5" camo extreme so I hope there is no rubbing going on now that the anchor point is now higher on the drop bracket. I have not messed with my air pressure very much yet but I can tell that I will be able to run less psi in the shock now. I was using the max 150psi I thing I should be able to run under 100psi now.
I did the geo mod on my sled 08 1000 sno pro, I couldnt tell if it rode any different and the sled was always sitting like the shocks were sacked out, after riding, wait a min pick up the bumper and it would stay, however i played with the stock settings and geo's setting, honestly I couldnt tell the difference in ride.
I then added a 2.5" camoplast and couldnt run Geos mod what so ever the paddles were hitting the underside on the tunnel HARD!
set it back to stock and had fun.
the stock camoplast is almost worse than the maverick! brutal tracks!
B
So this mod won't work with a 2.5" track? Anyone think that it helped gettin on top the snow faster? Was thinkin of trying this on my 06 m7 but i might just wait and see how it works with the float conversion.
I in no way mean any disrespect to GEO but I did the mod to my 1000 and m8. It did improve the stutter bump ride to a great degree but I feel that it hindered deep snow performance. So I ended up back at stock settings not as nice down the trail but better on the hill.
