1495 with 72.7 hrs
I Ride Eastern Washington 2000' to 6700' primarily 5500'. SLP pipe/can intake stock reeds. 10-70 weights 140/330 front spring must be stock helix in driven. Constantly vary the throttle to stay out of mid range especially at lower trail elevations. Only see 7950 RPM on climbs at altitude, but get 8300 on max RPM resets, so maybe I don’t look long enough, or only look when I don’t really have it nailed?
Only problems: Flat track shock ~300 miles. Delaminated belt ~270 miles warranted.
Last Saturday smelled belt for the first time; sticky snow and climbs through trees with about 700 miles on belt. Kind of maybe felt a slight bog on the trail home? Herd metallic clanking coming down very - very bumpy trail. Stopped a couple of times to check for loose stuff, looked everywhere the spark plug wrench and belt tool were out of place, not sure if enough to make the sound; so I changed chain case lube, lubed suspension, checked bolts, engine mounts, changed back to belt with 400 miles on it, changed spark plugs, washed clutch faces and belts, checked for any loose or damaged wires, and drank about 2 ½ Black Velvet and Coke’s out of a quart jar!
Cleaned the hood and did the same ride the next day, no slight bog (not that I was trying to induce it!). No clinking sound! Seemed to be snappier on the ride home? Maybe the belt wore too thin and the clutch was clinking???
I added my extra fuel before the return off the mountain.
Could one of the possible problems or another symptom be that when the tank is low and less head pressure that the fuel pump is not keeping up with demand and causing even more of a lean condition in that mid range injector “blind spot”? It happened to my carbed 600 last year when we added a pipe and V-Force reeds? The shop changed the fuel pump and location and the routing of the fuel line, never a problem again!
Had me thinking the sled just didn’t want to go home! If someone would have brought me a tent, whiskey, and fuel we’da’ never found the problem
