J
Here is my setup for an o7 m1200 with origanal ecu programing. 3000 0 0 0 5000 2 2 2 6200 4 0 0 6500 4 0 0 6850 0 0 0 7250 5 10 12 7850 10 20 35 45to46 pounds fuel 40/34 helix with green sno pro spring in a torsoinal setup 4 67.5 dalton adjustables with about 4 grams added in each one dd130/330 primary spring 046 belt dd1200 pipe ypipe and barker can small timing key that comes with kit and two base gaskets pulls 7600 to7850 at6000 to 7500 elevation air fuel gauge reads 12 to 12.2 Have rode this at 2000 feet also without touching the cntrl box 500 plus miles on origanal belt and has never missed a beat. Hope this helps.
Two base gaskets huh? Did you do that to raise port timing, or drop compression?
