J
Well here it is. I traded my Turbo Apex for a 1200 in hopes to make it my next big sled. Made the trade in a parking lot so no run time, and it looked great and sounded fine..............
Over 40 hours into it including a new top end I still cannot make this thing run, even on the stand.
Here is what I have done: New pipe temp sensor, reprogrammed Bd Box, new top end, different air sensor, different Servo motor, checked and double checked cables, fuel as much as the Bd box will give, took fuel away (hence the top end), Ran diagnostics at the dealer, oil delete kit, tried a different computer...... Fuel pressure is at 43ish psi. Reeds "look" good. Infact everything looks good!
It will start up and run fairly decent until 6500ish rpm, or if I hit it fast it will rev good up to around 7300ish. With out the clutch I got it to hit 7800ish today, but throw it on the stand and 7100. If I go slow it hits around 6800rpm.
40+hours into this and I am lost. A month of my season gone from a bad trade. I would sure like any thoughts or suggestions.
Here is what it is: 07' M1000 with a D&D1200. Pipe and can. BDX intake and oil delete. Other stuff not relative.
Anyone?
Anyone?
