Axys stalls only on left turn?
I’ve got a 2018 Axys 800 that has run perfect for the last two months but suddenly today when ever you tip the sled on the left side (belt side) it stalls out? It doesn’t matter if your carving a turn or standing still and tipping it in the parking lot. There is no problem with the right side it only stalls on the left. Anyone run into this issue before?
summ8rmk
Most handsome
12,368
6,039
yakima, wa.
Wire short.
Pull the plastics and look at every wire for bare spots.
Sent from my SM-G998U using Tapatalk
Spiderman
220
41
Mn
Look at your throttle safety switch too and throttle cable...the tss could be more affected one way vs the other
Nice! Thanks guys! I’ll pull the plastics today and check it out! As for the tss someone in on other message board said the same thing but I’m pretty new to this sill I’ll have to u tube mechanic it! Thanks for the help!
