Re-measured and my 9R secondary has 0.018” float and wife’s 850 has 0.027”.
On my last trip to the mountains I picked up some 14-74 weights from a dealer. Riding with the stock 140/330 spring at 6500ft in above freezing temps I was revving 8500 on my 165. So next day very similar conditions went to a 120-320 spring and was seeing 8450. However the new 74g weights made the sled nearly unrideable to me due to excess vibration in the bars between 5000-6000rpm. Polaris must balance the clutch fully assembled because the 74g’s weighed similar to each other, but it turns out one of the original 72g weights weighed a gram more than the other two, and the sled was pretty smooth with those weights in there.
Ibexx kits were on for 15% off so I decided to go that route, since I’ve been hearing pretty good things the last couple years about Ibexx on the 9R. The Ibexx weights loaded for my altitude weigh dead on 59.30 grams. I guess they use a different weight profile and helix angle to load the sled, so I’m really curious to see what lightening up the primary clutch that much does for the response. I ran the sled up on the stand and engagement is around 3750 rpm. I installed the kit and then had the primary rebalanced fully assembled at an engine shop. I doubt I’ll get a chance to ride it this year, unless snow conditions change in BC.
Trying out this bearing under the gold cup that is supposed to make shifts smoother. Also put two slip washers behind the primary spring.
