858 on the dyno
Vern
2,455
1,285
hyrum utah
At Dynotec, 167hp around 7800hp.
hansenmac
549
466
Deering ND
40 more than the 600 will feel awesome. but should lean it out and rev it up so its a piston eating rod breaking nightmare but man would it sell if the dyno said 175.
Old & slow
728
393
Alberta
I was told by Andy Bevis that the 858 made more power @4000 miles than it did @400 during EPA testing. He didn’t say how much more just more.
MTsled3
723
684
93
Belgrade, Montana
The 600 on the same dyno was 122. So basically 45 more. The 9r made roughly the same or a little less until it had several break in miles on it. Then it was like 170. Same dyno
You wouldn't happen to have access to the dyno chart for the 9r, would you? It would be good to compare powerband of the 9r vs. 858, and even both 850s too.
clutch
200
Big Horns Wyoming
The dyno chart is basically a mirror image with the edge to cat for 3-4 hp at certain rpm ranges until the cat peaks at 7800. Then the 9r keeps revving and peaks at 8300-8400 rpm and 170 hp. I dont know how to attach the chart or I would do it.
BeartoothBaron
1,249
1,326
Roberts, MT
Interesting to see the 858 being torquey and lower-revving - more like the Doo 850. Given the similar bore/stroke to the Polaris 850(840), I would have expected the power curves to be similar. But then I wonder, other than the power drop, if the power curve changes any at elevation. I wish somebody had a dyno at elevation: these near sea level numbers are really kind of worthless for me and most mountain riders (and I know, some of you guys in AK, BC, etc. are down lower). That'd tell you who's tuning for the best power at elevation, and who's just chasing numbers. Anyway, it's good to hear reports that it pulls as hard as any NA motor, and if it's durable, I'd say job well done for Cat. I don't think they need anything else, but that's partly personal. Aftermarket turbo kit sales will be telling as to whether Cat "needs" their own turbo sled.
kanedog
Undefeated mountain clutching champ of the world.
3,112
3,873
I notice perfect placement of the hp/tq curve. 8000 is rpm perfectly on the backside of the torque curve so when the engine is loaded on a big climb, rpm’s begin to drop, the engine falls into more torque. Nice. So many torque curves make no sense and seem willy nilly. I think this factoid will be part of the secret sauce. Cat sauce that is.
There’s a 10% drop in power in 200rpm, 7950 to 8150rpm so it’s important to be at 8000 on the nose. Aftermarket pipes will give many tuning options and different power bands for your performance needs. Exciting
