It really depends on what you want. I see your in co so I am guessing you do a far bit of deep snow riding, climbing, etc.
So to get a wheelie monster and a true mountain sled you will be a different ends of the clutching scale, and suspension setup.
If your after wheelie's only.
I would run about a 51 helix, I don't think you will pull a 53 at that elevation. Run a red secondary spring in about the second to loosest hole. Leave the primary pretty close to stock. Now to get the front end up. drop the front suspension mount in the lowest hole, and let the limiter strap out all the way. soften up the rear springs. It will get with it then. But it wont' climb for crap, it will be a trench monster.
To get it to climb at that elevation I would run a 49 straight cut helix yellow secondary spring in the middle hole, leave the primary stock, But don't be afraid to spin the rpms up. then put the front suspension in the upper hole, suck up the limiter straps a bit. You need to try and keep the front end down to get the thing to really start to climb.
But they are a blast.
The wildest wheelies on those is with a Broken limiter strap. (honestly it is just out of hand at that point)
Super fun sled overall,
Thunder
