1999 ZRT 800 motor, motor is stock, has one bad cylinder and head, motor is in pieces, everything that is included: crank, cases, 3 cylinders and heads, 2 pistons, counterbalance shaft, water manifold, water pump, water pump housing, magneto coil and cover, all the bolts for the motor. This motor was tore down thinking the crank was bad but it only had broken a piston skirt, found a new motor that I put in the sled so this wasn't put back together. This was last year. This motor could be running with a new cylinder, head, and piston. $500 360-578-0588
