In regards to the older shafts and sprockets.
TS kits use a 25 mm shaft just under an 1", so no replacements out there in general machine use, I have machined down 1" shafts and tried to outsource them, all a waste of time.
I wouldn't sweat getting the shafts and sprockets changed out as a first order of business, get your turbo running first. BUT for sure a FYI you need to be aware of.
. Originally TS had a kit and reasonably priced to convert to the newer splined shafts.
The only cost effective conversion now is to simply get with a TS parts person and buy the parts.
If you can only buy the driven shaft and not an assembly, not sure what Polaris is offering there, just buy the shaft and press your old sprockets on.
The brake disc is kind of a miserable situation if you try to replace it all. You really don't need to do that, but you will have to have a machine shop mill the key way for your disc brake ( so little stress on this keyway/key down one of the female spline grooves and with the old key you will never have a problem) . If you get to that situation, just pm me or and we can talk about that. You will have to make several spacers to complete the project, TS doesn't have all the correct parts, but if you are launching into a turbo project, a spacer better be very elementary.
I have converted a half dozen or so kits, from the first year on up, way better, quieter/safer/less maintenance, been a couple of years but about $400.
I had to get the sprocket changed out, the teeth were getting way to thin to ride even stock, I know for sure it would not last a day turboed! I'll upload a pic of the old sprocket tonight. After pulling the sprocket and seeing the condition of the shaft, I knew it wont hold for long either.
Seeing the prices of timbersled parts, the limited availability of anything in 25mm, +shipping cost and wait times, I upgraded the whole jackshaft and bearing assembly for a 1'' and got all the parts in town at a local industrial supply store. Its a way better setup as now if something goes out I can walk into autozone and get a new 1'' bearing.
I got a 36'' keyed 1045 shaft, a hardened tooth #50 sprocket, and bearings for $150 And I still have 29'' of shafting left for another rebuild or project, and I think thats still less than what I would have paid timbersled.
Drilled and tapped the shaft ends for a slightly smaller OD bolt than stock, to give it more meat as the sprocket rides on the very end of the shaft. Used the same bolt on the brake side.
The # 50 sprocket has a much wider hub so it should last longer with less wear on the shaft/keyway. But its also much wider at the teeth, so I ground it down on the lathe with an angle grinder- my carbide wouldnt take those hardened teeth.
The wider hub also bumped up against the bearing housing, so I took some material off for clearance, and filled in that pocket with grease for extra water protection
![Face Icon Small Wink :face-icon-small-win :face-icon-small-win](/forum/images/smilies/old/face-icon-small-wink.gif)
there is still a 1/8'' brass bushing/spacer between the sprocket and bearing inner race.
For the brake hub I just opened it up a bit on the lathe to fit on the 1'' shaft, and same thing on the spacer. When the rotor goes out I'll just replace it with an SAE setup- proper spacing is critical there.
On the sprocket side, for some unknown reason, the spacer was hardened steel!
![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
.... couldnt turn it on the lathe so making another spacer...
I also went up 1 tooth on engine sprocket and down 1 tooth on jackshaft sprocket. I'll post updates on how it pulls when I hopefully take it for a ride this weekend.
If this keyed shaft setup doesnt hold out to turbo power- like someone had mentioned earlier, then next rebuild will be with a splined shaft.
