I'll call and ask, but I dont think they see anymore info than what I do looking on parts diagrams and stuff... I'll try asking on thumpertalk
if your gonna be disappointed in a turbo snowbike then you shouldnt be out on a snowbike at all
Have now ridden turbocharged snowbikes for 7 years. Tested different setups on several bikes.
I see that many snowbikers look for high power up to +100 hp.
Have tested this and run with boost up to 0.8 bar and close to 97 rwhp.
The problem is that reliability is deteriorating when you go for such high boost levels. We all want high power and a rideable bike that holds up more than 100 hrs without rebuild, right?
As soon as you go above 0.5 bar, extensive engine modifications will be required and yet it is uncertain whether the reliability is sufficient.
It will require substantial modifications like a custom piston, custom carillo rod and head studs. Expensive modifications literally.
In addition, different bike manufacturers have different bearings of the crankshaft. Most have roller bearings, which I think is a weaker bearing for turbos. KTM 2016- has journal bearing that is much stronger i.e. more suitable for turbocharging.
I’m pretty sure Yamaha is running roller bearing crankshafts ....
From my testing, a stock conrod will not hold up with 0,8 bar. Have looked for a custom Carillo but it wasn’t easy to order and also expensive.
After comparing 0,5 bar and 0,8 bar boost, the driveability is almost equivalent boosting 0.5 bar. Slightly lower peak power but significantly simpler build and with really good reliability. With my current 0,5 bar setup, I run with the engine completely unmodified. Simple assembly and no special parts. Just a reinforced clutch.
I see that many snowbikers are hesitant about turbocharging their dirtbike. I think this is because many who have tested turbocharging have run with too much boost, pinned it to the revlimiter or with a questionable turbo design. Not good for everyday snowbiking.
50% more power is awsome, compared to 80% and a broken engine, right?
I suggest you go for a stock engine and run less boost. From my testing, 0,5 bar looks to be the sweetspot.
I’m running MCX piggyback barometric compensated TCV boost control. This means that more boost is added as you gain altitude meaning that you have the same power at sealevel and 10000 ft. Not sure if KMS have this feature?
Many people think that racefuel is expensive and look for cheaper solutions. Here in Sweden, race fuel is more than twice as expensive as pump gas.
Still, I think it's worth paying the extra cost for race fuel. I run with 102 oct MON, a moderate octane fuel. This fuel is kind to rubber seals/hoses, plastic tanks and the bike can be left fully fueled without problems. In addition, it is storage stable and can be stored for a long time in standard plastic containers. I use this fuel just like any pump gas. Higher octane numbers are more expensive, requiring epying the tank after every ride, cant withstand sunlight (transparent fuel tank) and have a limited shelf life. These fuels are sold in metal containers.
In addition, snowbikes consume about half the amount compared to sleds. Not to mention that the cost of expensive blown belts is eliminated ....
I dont know if 100LL avgas or a mix of pumpfuel works similar to racegas. Maybe, maybe not... Cheaper but maybe not if you grenade the engine due to poor fuel quality?
Never toasted a clutch. Double springs seems to work just fine.
Rekluse was a nightmare, it was slipping most of the time. Nice idea but it doesn’t work with a turbo. Tested different oils. Tried different springs on the expantion ring and heavier weight. Sad to say it but it just does not work with a turbo!
You be disappointed as well when a well set up big bore kicks your but in the trees and any technical riding -- there is a reason the snow bike turbo Idea never really took of.
I had an sx and I went with the biggest front I could... So I could elongate the gears... The problem you have to balance is when you get stuck not have to high of gears so your clutch stays in one piece....
Be very careful with filters they most likely will freeze and if the case pressurizes you start blowing gaskets and or seals.
Also make sure to have a 1/2 inch slit lengthwise close to the engine in the breather hose just so if you have a freez up you do not blow any seals.
Just the hose going up and around the cylinder and finally ending up on top of the cylinder is all I have and never lost any measurable amount of oil.
A pressurized crank cases loose a lot of power. For maximum power it is beneficial to have a slight vacuum on the breather, but be careful this also will increase oil consumption especially in worn engines.
I’ve been boosting for about 6 yrs on sleds and now my snowbike and have always found straight av gas is the ticket. I always ran 10psi on my sleds and will run 10psi on my bike once I get a smaller turbo. (My current turbo is too big). Av gas is very consistent and 100octane or better. It smells good and evaporates fast and doesn’t make ur hands stink if u spill. 3-6k is not that high elevation and I would listen to Sweden turbo and only run 7psi. On a 4 stroke at 11000 rpm the crank only pushed half as many times as a 2 stroke so it has to put a lot more strain/pressure on the rotating assembly in order to make the same hp. I suck at explaining my theories but that’s how I think. Run straight av gas. Don’t listen to people who say the lead will destroy your oxygen sensors because I’ve never replaced mine and have about 11000km on the sensor
