H
Holomis International
for doing the pipe, you go to where the stinger is welded into the fat part of the pipe, cut around on the fat side of the pipe, just through the outer layer, leaving the stinger intact to make it way easier to get out. you have to go about 1/4" in from the weld as the end of the stinger is flaired inside, and it needs to be able to fit out. take the stinger how that you removed it and then cut the peice that goes into the fat part off.. reweld. done.
QUOTE]
If you cut closer to the current weld, you can pull the end with the stinger out to the flare, cut as close to the flare as you can, and dump the flare out the engine side of the exhaust. Then cut off the remainder of the stinger. When you reweld, it only appears to have been welded one time for a cleaner look. Either way works.
Great thank you for that info!
Jeff
