XP Graphic Wrap Install
Looks *****in. Did you use soap and water to put them on? Justin is doing some stuff for me now can't wait to see it. Also did you have to take the fuel tank off or does it go right against it?
My wife owns a graphic design & sign business so i used vinyl application fluid. But water with a LITTLE soap works just fine. I didn't take it off, it just tucks right under the edge of the tank. Don't be afraid to use a little heat either. The material he uses is made to stretch and form to the surface, so heat will be neccesary in certain areas. He does some wicked work, you will be happy. Good luck man,let me know if i can help you anything else.
