XP 154 gear change and DJ's clutch kit
I keep hearing that a lot of folks got their dealers to change the top gear in their XP 154" sleds to a 19 tooth under warrenty. Was there an actual BRP service bulliten authorizing this gear change? I have recieved my DJ'S clutch kit for my XP and was wondering if I should have my dealer install it or should I take a crack at it. I have the tools to do the primary myself, but changing the helix would be all new to me. What are my options here?
Thanks and Fish On!!!!
Steelhead Slayer
Yes on gear change. BRP will pay for it.
Clutch - Springs would be the tricky part unless you have all the tools.
Steelhead Slayer
secondary tool is needed,but you dont have to pull shaft
I called Mac's Cycle today to set up a time for the gear changes but apparently they have been waiting on 19 T gears for a little while now. They do finally have my belts in now! Only one for each sled. I am going to have them install the DJ clutch kit when they do the gear change. Other than add the DJ parts to the secondary and primary clutches is there anything special I should request them do while they have it all apart?
Steelhead Slayer
