X3.2 on PRO and XM is working!
R
realbass
3.2 is working on pro and XM also.
We installed a few 3.2 tracks on 15PRO (avid 7t drivers) and XM (non T3) with t3 driveshaft.
Pro
XM
I dont think ive ever seen a metric tape measure. Hah. Did you.do a drop and roll?
Sent from my SM-G900V using Tapatalk
Just because you can get it in the tunnel doesn't mean it will work worth a damn. Holy zero clearance batman!
clearance is a myth Robin, ever turn sled over after riding, Without a front cooler the ice builds up to the paddles which scrapes it and keeps it there.you have all that room in the paddle itself to roll the air around.
Yup.
Right in there with:
"venting" helping clutch heat.
Belt drives being more efficient.
Greased crank bearings.
Cageless wrist pin bearings.
Ect......
That 3.2 looks like it was made to go there. :)
78mm /25.4 = 3.07inch actual dimension of paddles on 3.2 track.
I did not do any drop and roll. Stock 2015 PRO with TKI drive system and avid 7t drivers.
Did you fit the 3.2 on the Pro with just the Avid 7's ?
Yes i did with just 7t drivers with out any additional mods. Does it correct.
